TwinTurbo.NET: Nissan 300ZX forum - Re: code 34 is your det sensor. Replace or bypass it.
irieblue
on May 04, 2008 at 11:09 AM
code 34 is your det sensor. Replace or bypass it. (n/m)
posted by Waggz
on May 04, 2008 at 11:06 AM
yeah but I'm at 13 degrees if the det sensor was causing retarded timing I'm thinking it would be alot worse...plus I dont think its a long term code 34 caused by a bad sensor cuz it only came after I seafoamed.
I have nooo power!! Help??
irieblue
10:57:12 05/04/08
Waggz
11:06:31 05/04/08
Re: code 34 is your det sensor. Replace or bypass it. -
irieblue
11:09:04 05/04/08
34 code switches you the low octane maps.
TheSlimOne
11:15:42 05/04/08
Re: 34 code switches you the low octane maps.
irieblue
11:42:49 05/04/08
I disconnected the det connector and got 55>still no power
irieblue
13:59:50 05/04/08
have you double checked everything in the engine bay?
Waggz
15:23:23 05/04/08
You have to put a 1 Mega Ohm resistor in the female side
TheSlimOne
19:40:27 05/04/08
Re: You have to put a 1 Mega Ohm resistor in the female side
irieblue
22:36:04 05/04/08
If you disconnected the det sensor and the code is gone then
TheSlimOne
23:22:18 05/04/08
I would check your timing job
300ZMang
20:24:08 05/04/08
Re: I would check your timing job
irieblue
22:38:35 05/04/08
Re: I have nooo power!! Help??
Noncon
21:30:28 05/04/08
Re: Re: I have nooo power!! Help??
irieblue
22:43:37 05/04/08
irieblue
14:28:24 05/05/08
Ohmmeter, 10-14 ohms is normal (n/m)
Noncon
20:49:49 05/05/08
